hybriduff
Hey guys! So, I've read through several forums and have read several threads about fz6s, r6s, ect not starting and I couldn't find a situation like mine so maybe someone could shed some light on my baby.
Ok, so first off, like an idiot, I left some gas in the bike over winter (2-3 months). I figured that this would be a problem, so before I started it for the first time this Spring i drained the tank, and replaced it with 93 octane gas and fuel injector cleaner.
It started right up for about 30 mins and then chippered out and died. Subsequent attempts at starting the bike resulted in 3-4 seconds of ignition followed by a weak 500-1000 rpms roll over and a quick stall out (pretty classic bad gas/no gas symptom). After a while the battery died...
So, I jumped the bike with my car and started doing some trouble shooting. The battery charged back up no prob. The fuel pump obviously ran fine with a nice 2-3 second hum as I turned the key on. When I go to start it, still nothing, same bad gas/ no gas symptoms. I started spraying starting fluid into the air box and it fired RIGHT up no prob. I kept it going with 'as needed' sprays (hoping to clear out the bad gas). After about 30 mins of doing this, the bike still dies after the starting fluid evaporates.
What do you guys think? This is a 2009 FZ6 with only about 2100 miles on it. Oil is fine, and I think its most definetly a fuel problem, everything else runs fine.
