So, in with doing my spring maintenance I decided to change the fork oil. My bike is a 05 FZ6 and I have had it since June 2010 at which time it had 7200 miles. This spring it is at 23k and change. I can say with relative confidence that the fork oil had not been previously changed, and i didn't realize how dirty it becomes. I say this as I have the original bill of sale and all maintenance receipts from the previous owner. :rockon:
All I could find in the service manual and owners manual was to inspect and check for leaks. Seems like this should be an item on the scheduled maintenance list, or am I going blind. From some online research, this seems to be a topic for debate but most say it should be changed (yearly, every oil change, every other year, etc.).
All I did was take the forks off, turn them upside down, let them drain and pump them a few times by hand. Refilled with 5w fork oil. I suspect at some time I will have to replace the seals, but they are not leaking.
Note: Yes the oil has something it it that makes it form the funky colors but I did not find any signs or moisture in the oil or signs inside the forks.
Also, the new oil is clear so we will see how it looks next year.
