sheltiedave
Went to fire up the bike last weekend but there was no life , so just thought the old battery had died as I have no idea how old it was .
Put on a new battery and she fired up no problems . Being a nice day I went out for a run and after a while noticed the orange engine light came on , pulled over , switched the bike off to have a look around , found nothing . So went to start the bike again , but another flat battery after about 40 miles .
Got the bike home , recharged the newest battery and did a test . Battery sitting in the bike 12.9v .Started the bike up and after a few minutes of warming up tried her through the rev range up to about 5000 rpms and the battery was always dropping volts down to between 12.2-12.3 volts .
Tried taking a reading from the 3 whites wires coming from the stator and getting 00.5 ohms but if you hold it long enough it goes down to 00.4 ohms on all 3 wires .
The book says 0.22 to 0.34 , so is the stator packed up since I'm getting higher reading or regulator/rectifier problem .
Can the stator be physically inspected for sings of wear/problems ?
