You are right on that. I definitely won't have the bike forever. I'm just skeptical of the overall durability of the JB weld and if the oil will erode it or cause it to break apart then there is a chunk flying around in my engine. Lots of possibilities. Just gotta make a decision I suppose. Question though, once I get the new stator and generator installed and if I were to bolt on the case, would the engine start at that point? Even with the hole on the block?
It will run.
Just like Marthy said and I mentioned up top, the only way you weld that stuff is to bake the oil out of it. Otherwise it just splatters EVERYWHERE!!!
But, aluminum is pretty forgiving and if you take your time and heat that area slowly, slowly slowly till its 325F (it gets to 200F on its own but in a bigger concentration), this will displace the oil so it can be welded. EVEN IF YOU JB it, do this, scuff it with a aggressive paper and the stuff will stick!!!!! Wipe repeatedly with lacquer thinner or acetone. Now if you wish to make it last. Scuff it lightly with 320 grit and cover it with interior engine sealant. Again, the prep is what makes it work. Anyone can smear **** on it.....
But first get some tools to check out the crank. You can rent what you need!
