tucker
Hi all, newbie here both to the forum, and to my FZ6. The previous owner did a side-of-the-road clutch cable replacement, and I'm trying to replace it with the OEM version, but having a hell of a time routing it correctly. Two questions right off the bat, for those of you who have done this before:
Did you need to pull the airbox to get it between that and the frame?
Did you run it through from the lever end down, or the clutch end up?
Any tricks to making this work are much appreciated. I feel like i feed it part way, and it gets jammed on some invisible part of the bike every time.
