A lot of already very good input already.
I'll just add this:
Don't be concerned with going "fast". Trying to be "fast" results in things like charging the corner (trying to compensate for the feeling of being slow by hammering the throttle entering corners), and then trying to find the maximum pace at which you can retain some degree of looseness and make the corner.
You learn nothing this way except where your own panic responses flair up.
The adage is "slow is smooth, and smooth is fast." It is cliched, but very true. Focus on being smooth and clean in every respect going through corners: work on your body position, throttle application (on, off, and maintenance), transition from braking and rolling off the throttle to getting back on the throttle and straightening out, blipping the throttle and timing your downshifts, coordinating everything so it coincides with an appropriate braking, turn-in, and throttle point etc etc. All of these things work together and you will soon see that cornering a bike is more about integrating rider and machine and one series of actions that is quick and smooth. The better you get at this, the quicker you will ride. Thing is though, even as you get quicker, you still work on the exact same things. It may or may not become an obsession, or it may just be a casual thing you enjoy tooling around on back roads. Either way, it's a fun process.
Gradually you will notice your comfort levels rise, your lean angles increase, and your pace quicken. You went slow, but were smooth. In being smooth, you started to ride faster.
But FYI: You will notice more and more all the things you would hit if you slipped, especially as your pace picks up more and more. That's a good time to look around you and notice the terribly unfair concentration of phenomenal race tracks the UK has. Lol
[P.S. a good tip I got was when working on the basics entering a corner, don't worry too much about blipping the throttle and instead just wait till your revs drop and delay the downshift so you don't need to blip. Get everything else working in unison and clicking properly. Personally, I've found I'm much happier delaying the downshift than blipping. But will have to get a slipper clutch one day though. But I need a motorcycle first. Lol
I'll just add this:
