Dead high beam dashboard indicator
spock
Medellín, Colombia
Hello everybody
When taking my 2008 naked FZ6 for a spin this past weekend I noticed the high beam led indicator is not working, but the light is
Any advice for checking/replacing it?
Regards.
I am also curious about this. Mine isn't dead but has a short in it somewhere. Occasionally after going over a bump the light will work properly until another bump. I never bothered to take the cluster apart to get in there to find it; I didn't want to risk it not sealing properly afterward since I ride in the rain fairly often.
If you check for a single black/white(it's in a sleeve) wire on the throttle side of the steerer-tube,there's also a connector there.The wire has come away from the connector(my guess...it happened to me):thumbup:
Wow, there's actually a separate wire for that indicator? I wonder if the '06 and older bikes are the same. I'll have to take a peek tomorrow. Hmmmm.......
Just had the time this weekend to deal with the problem, I also changed the main bulb for the wonderful Osram H4 all season, pretty nice light for every condition.
Exactly the same problem as you :D
The wire got away from the connector as well, exactly the one that comes from the controls cluster on the left, so I joined it again and it's working flawlessly again
Thanks a lot buddy:thumbup:
