Dragonryu
Hello Guys
So maybe you can give me a hand, I installed some HID's with angel eyes and LED strips and since then I get ERROR_1 when I shut the bike off. I only get error 1 when my battery is drained, and apparently is when the ECU is not getting signal, all the installation is ok, so I does not have to do with wiring issues.
Also when I turn the high beams on the head light fuse burns (not instantly, but can take some minutes or some seconds).
The bulbs are 55W and the wiring harness is 35W/55W, and the fuse is the 20amp that came in the bike.
Not sure if someone else have had the same problem.
Thanks for your help guys.
