vinmansbrew
Well, I just drilled and then used an easy-out on the little bolts. The actual switch looks good. Doesn't look like any bad solder joints. While I had everything apart, I set the pc board in the housing and slipped on the contacts and fired it up. While like that, I wiggled the contacts and wires and it never cut out. Maybe the board and contacts were just a bit dirty. Possible seeing as how the bottom of the switch is open enough for junk to get in there. Cleaned things up and put on some dielectric grease, and I'll see what happens.
