GrayHatPaul
Hi all,
I had my local dealership install a Soupy's lowering link but I think they performed the install incorrectly.
I say this because a few months and a few hundred miles later, the threads on the bottom of the rear shock stripped off and came free from the lower mount.
The dealership claims no responsibility for a faulty install when it clearly looks like they only screwed the lowering link half way onto the shock.
So now I have to save up for a new shock ($305 for stock at Boats.net) and another lowering link ($79).
I am considering attempting the installation myself and need to call on the expertise of you other forum members.
1. Do you have to drop the rear tire or chain to remove and replace the rear shock?
2. I understand a shock compressor (small enough to fit onto the installed shock) is required, any suggestions on brand/model of an inexpensive but quality spring compressor that will only be used once? Anyone have one they used once and would like to sell?
3. Any other gotcha's while doing the shock replacement that I should know about?
I also have to invest in a motorcycle jack as my FZ6 no longer has a center stand.
Thanks for reading and more importantly, your responses.
