I have my fairing here which I cleaned and waxed (no not pulling hairs, the protective hand rub wax!), the gauge cluster, a wiring harness, ECU, CPS trigger and a battery! Sadly - no life from the gauge. Yes, numerous jumpers... perhaps less :beer: :don'tknow:
Anyway, plan was to verify trigger alone powers system on. Maybe it wants some "feel good" from all of the missing sensors?
Oh well!
OK I have a hit list!
Need a Lean Angle Sensor
A TPS and Vacuum Sensor
Bike has 5 bars of fuel, is running at 174°F and air temp of 84°F....
A fleebay TB assembly is $50 and has TPS and Vacuum sensor as well as injectors. Likely going that path.
Then we'll need the Speed sensor. Sadly bikes oil level light is off when turned on but flashes 10x. Perhaps because lean angle thinks the bike is on its lid? FSM says test it and expect 1 - 4 vdc out. I've tried all static ranges and get either error 30 or 41.
Apparently I need some OEM parts!
