- Joined
- Feb 7, 2009
- Messages
- 12,920
- Reaction score
- 1,725
- Points
- 113
- Location
- Cape Coral, Florida, USA
GREAT news!!!
Did he mention if it jumped a tooth???
GREAT news!!!
Bikes now fixed and fully serviced (picked it up yesterday). I asked him if it had skipped any teeth on the cam and he said a couple, but he said he didn't know exactly how many as he reset it correctly without double checking He didn't change the cam chain just the tensioner assy. Unfortunately I've still got a flashing oil light, he rang me about this, but he couldn't remove the sensor without loosening off the headers and as the place where the headers connect to the "manifold" was pretty rusted up, it could involve an expensive repair, so I opted to leave it as is for now.
a few studs snapped when I last removed my headers, I was able to remove them with a stud extractor, some heat, and penetrating oil (which I don't think helped). I replaced all the studs and used plenty of copper grease (so I hope they are still ok)
So what ever happened with the flashing light?
Did you get it resolved?
My test hardware is having the same issue....
If you want to kill the flasing light here is an option but clearly bypasses the intent of the light.
Under the fuel cell is a single conductor white connector and white wire. Unplug it and connect a 1/4 watt 250 ohm resistor to it. Connect the other end to ground. The light should turn off.
Because of the type of connector, the use of a posi-tap on thr harness side into your resistor would be good option.
We are talking 15" of work and Perhaps 3 Eur in parts....
Let me know I'll get more specific....
Wire.
Resistor
Eyelet crimp connector
Positap...
In the states less than $3 USD for material. Now if you dont care to lift the tank and dont mind just cutting the exposed wire outside the chassis, light is off in 5".... PS this only goes to the gauge.
If I were blessed w this, I would do this to verify the integrity of the wiring harness. If it tests good, then we know the fault is from the wire to the oil sump sensor.
Mind you if you can sneak 10mm socket up there to the sensor, its potential that 1/4 of one of the bolts fixes it as the bolt acts as ground path from the sensor to the pan. If loose, it looses contact. Causes this.....
I know you can reach one side, but the other could be a problem. Try it. Maybe you get lucky. Ps no risk of causing a leak.
Last little bit; if I wanted the header off with no risk, A cut off disk slicing into the nuts diagonally but avoiding the stud, apply penatrent, then heat, then very gentle turn. The nuts will split if cut right.
You clean the threads with die and install new nuts. Figure an hour to cut them all. That would be my path.
If it's the oil sensor light, it just lets you know your low on oil, NOT LOW ON OIL PRESSURE.
As long as you keep an eye on your oil level, I'd cut or hot wire the harness to by pass it (as noted above).
Re pulling header. Find a good machine shop. With some intense close heat, those nuts can be removed or cut off as noted above.
Run from the guy telling you to get a spare head...
You can buy the studs separately and put brand new ones in there...
Even if a head "HOLE" stripped, a heli coil could fix it.
If you decide the header is coming off start spraying those bolts / nuts with penetrate..
***Quite awhile ago a member here had a screwed up head and got coolant leaking thru one of the exhaust bolts. He fixed it, (forgot how, maybe sealer),
but use caution drilling the head...
