b.polley11
I think Ive got a bad ecu on my 2009 fz6. I was wondering if anyone knew if the fz6 and fz6r ecu's were the same. thanks
Sounds like a painted ground, especially if the engine runs when you provide a ground path for the injectors.
The ECU likely didn't break sitting on a shelf...
I seem to remember this exact same discussion with the FZ6 that was either this same poster or another member. No? Yes?
Thats what I had originally thought, but I guess i didn't have much luck. The engine does run when I ground the injectors, but by no means does it seem to be 100%. Any ideas on where all I should check for a ground, the wiring diagrams are difficult to follow.
Thanks
