raduph
Hey guys, long time no see.
I'm still aboard the fz6 train, hoping to move up to an FZ1 this season, but that's another story.
For a while now I've been having some issues with my transmission, the issue was described very well on an aprilia forum, I'll quote the guy as it's the same issue I'm having:
"Hi Guys,
I have a 2003 model with 6500 miles on the clock.
Is any of you getting driveline slack on your capo? I.e. a 'delay' between accelerating and the rear wheel responding. And an obvious clunk once the chain begins to pull on the rear wheel.
I know that certain amount of slack on the gearbox and the output shaft are needed to make shifting easier, as these gearboxes don't have synchros, and I also know that certain bikes are worse than others (Yamaha FZ6!!), so I wanted to run this past you guys before I really start worrying.
It manifests itself at all times, but gets worse in higher gears and lower revs. So if I'm in 4th at 3k, throttle off and then throttle-on again I get a positive delay and a clunk before I get drive on the wheel.
It also happens when changing gear because I have to throttle-off and on. In between I get the clunk.
I just want to make sure that there's no known issues with output shafts or the like because I'm still within the 30 day warranty offered by the dealer I bought the bike from. So if there's something wrong I'll get them to fix it.
Cheers Guys!
Mich"
In the discussion they mentioned bad "cush rubbers" and worn out splines on the drive shaft.
I also think I remember having a striped nut holding on the drive pinion from when I changed the chain kit.
It's really getting on my nerves, any ideas?
Cheers.
Edit: The bike has 59.000 km on it atm, I've only done like 10.000 kms on it in 3 years and no abuse, I never redline and no wheelies whatsoever, and I mean never.
Serviced each season even if not doing 5000km, fresh filters, oil... the works.
"Hi Guys,
Cheers Guys!
Mich"
Cheers.
