SteelRain
It's always worth it to have the right fuel going in for the amount of air it's moving, and "rejetting" is for carbed bikes vs the fz6 being fuel injected but same idea. The CO adjustment is actually built into the bike so it's free all you have to do is ground out a wire in the main wiring harness so nothing is needed but your time and some effort.
Here's some links to some threads about it
http://www.600riders.com/forum/how-t...an-richen.html
http://www.600riders.com/forum/fz6-m...-vince-18.html
Solid man what adjustments did you make and you can pull the ground out after your done adjusting correct? Some guy in that thread was talking about riding around after and his ground tripped an engine error code and then he just pulled it out and everything was good so do you leave it in or out? What did you run your ground wire to just the frame or somethin
