hk_fz6_05
Ok so spent the day in the garage. Recently acquired a genny (no power out there) to run a compressor off. Got them both used but made sure (I thought) to have enough spare power on the genny to run the comp easily. Well. Not happening.
I turn the genny on (runs beautifully), let it run for a while to warm up, then hook up the comp and switch it on...and ....blah. The genny dies straight off.
After a couple of tries I managed to keep the genny going by adjusting the fuel intake, but only just (it was literally bouncing up and down so hard I had to steady it by hand to avoid it bouncing around the garage floor) and even then it didn't fire up the comp in any useful way.
So having very little experience in these matters I come to you for help. I've included the data on both machines and it would seem to suggest that I shouldn't be having any problems, so why am I? Am I missing something glaringly obvious? (I know the comp runs off the mains grid)
Any help appreciated!!!
(the genny is pic 1 and comp is pic 2)
