DefyInertia
Former '04 FZ6 Rider
"You must spread some Reputation around before giving it to Boneman again"
haha
haha
And since when is the VFR faster than the FZ6???????
I thought a VFR would be faster as it is an 800cc bike correct?
Remember, it's also about the rider. You could put an average rider on a FZ1, and a great rider on a lesser cc bike, and it becomes a lewd point. The skills kicks in, and the average rider on the FZ1 or R1 is left behind.
The little Fizzer's powerplant is built around the world-beater R6 mill, retuned here for better power at lower, more street-specific revs. The bore-and-stroke dimensions, combustion-chamber shape, forged pistons, valves, crank and linerless, direct-plated cylinders are all identical to the R6, though it does diverge internally in a few significant areas: reshaped camshafts, reconfigured inlet and exhaust ports, and a slightly lower (down 0.2) compression ratio.
how often are we going to hit triple digits.
It certainly makes more power than the FZ6 in certain places but faster it's not. I'm just being picky though...I see it as more of a move towards an FJR or ST type than towards an R6 in terms of power delivery, acceleration, and outright sportiness...
VFR Interceptor --
PERFORMANCE
Horsepower: 99.1 @ 10,750 rpm
Torque: 54.2 ft.-lb. @ 8750 rpm
Corrected 1/4-mile*: 11.26 sec. @ 119.50 mph
0-60 mph: 3.37 sec.
0-100 mph: 7.80 sec.
Top-gear roll-on, 60-80 mph: 5.07 sec.
Fuel mileage (low/high/average): 25/45/34
CHASSIS
Frame: aluminum alloy twin spar
Weight: 557 lb. (wet)/522 lb. (fuel tank empty)
Fuel capacity: 5.8 gal.
Front: 43mm cartridge fork adjustable for spring preload
Rear: single shock adjustable
PRICE
MSRP $9999
ENGINE
Type: l-c 90-deg V-four
Valve arrangement: dohc, 16v
Bore x stroke: 72.0mm x 48.0mm
Displacement: 781cc
Great bike though...I may consider one some day.
I was thinking more about this one.
Here's what I think one could do an build a pretty cool engine.
1. Exhaust - good for about 2 hp
2. Power Commander - more mid range as the lean can be tuned out, not sure what it will do to the high end, but mid range wins races.
3. Wisco 618cc piston kit. This thing is cool. slight bump in displacement, but the compression ratio is bumped to 13.5:1! Wow! :rockon: The kit is $634, but you will need to add boring and re-plating labor. So probably $950, if you do the tear down and rebuild.
4. Head clean up, not a full on port, but simply clean up the castings
I'm not sure what the total yield would be but I'd guess the engine would gain 8 to 10 hp on the top end, HOWEVER the mid-range would be much, much fatter.
That said, I think the FZ has plenty of power for me at this point of getting back into riding. I am still blown away that a 600cc bike has the performance of my 1100cc bike from 1981. Times they are a changing!
I would like to get the power of a R6 in my FZ6. I know they are basically the same motor. Does anyone no what the difference is? And no I don't want to buy a R6. I just sold one, to uncomfortable to ride long distances.
Want more power...don't buy a 500cc FZ6 then. sheesh.
Wait a minute... I bought a 600cc didn't I?
Good points all... I find it hard to believe that anyone can really use this bike to it's fullest potential.
Go get the liter bike and while you can run away in the straights, the FZ6 will wave vye-bye in the twisties.
84 hp at the rear wheel not enough?:Sport:
come on Top doooo it! J/K:thumbup: but on the performance point from 81 it comes down to lots of factors not just power, ie; better tires, better chassis, better suspension, and better brakes just to name a few. So to the original poster you can upgrade more than power to make it a "faster" bike and it will feel like a finer edged sword. If you are just racing a R6 and lost just get some nitrous! :rockon:
