pkoosa
The kit comes with fork springs, 15wt. fork oil, and rear spring. Instructions are included, but I used the factory service manual. Installation was straight forward using the manual. I took the rear shock to a local motorcycle shop that swapped the rear spring for $5, because I didn't have the right tool to do it safely.
Stock OEM Spring on the Left, HyperPros on the Right and uses the OEM spacers.
Front forks raised 10mm. (hyperpro recommended 5mm in the instructions)
Rear spring. The heft of the HyperPro spring can be felt compared to the OEM.
Nifty chain/wheel alignment tool.
I'm 215lbs. with gear and don't have a lot of miles on since installing the springs, but the difference is night & day.
