LED License Plate Light.
Chaosratt
Senior Member
Tampa, FL
www.computing.zone
Replaced the License Plate light wit one of these from Ozznium:
Tiny LED Modules : High brightness surface LEDs
used the round black one.
Simple install, the module comes with a wire length about 2 inches too short to reach the connectors, so I whacked about 3 inches off the stock light's cable at the connector side and soldered in a slice. Connected up and she's good to go!
Pro Tip: I washed out the light housing with dish soap and then wiped it down with pure isopropyl to get rid of any grit. The included 3M tape sticks fantastically well. Doubt I could get the light out again without damaging the light or the housing.
Before:
After:
Various of the light itself:
I had same problem with my bulb. So I put LED's on my plate. The ones from ebay that hold the plate. Nice and clean as well.
The nice thing about the way I did it is that it'll also work with the stock setup, and most any fender eliminator that uses the stock license plate light holder. Cost was $9 + S&H (I got several more lights to do under-body lighting in these cold days ahead).
