4drfocus
Rurouni
- Joined
- Jul 11, 2008
- Messages
- 593
- Reaction score
- 10
- Points
- 0
- Location
- Oz, or somtimes Japan
Now I'm scared to buy one, do we have other options?
PCV is meant for 09+ models ONLY
2 bros juice box
Because their website states:Why only 09+????
Isnt the 09+ FZ6 exactly the same as the 07, and 08 models spec wise???
Fz6 09+ PCV
FZ6 09- PCIII
I'm NO electronics or mechanical expert, so I'll only go with what manufacturers tell me.Right, the end plugs of the devices are the same and plug right in. The difference is no map for '09- for the PCV.
For example for my '06 FZ1 they only sell the PCIII, but the PCV works fine.
That said a new flash is the way to go, times change.
I had to send my PCV into Dynojet early on for similar symptoms and they did the reflash to correct issues with the batch injectors. Turn around was under two weeks and it has worked great since. Over two seasons and many updates later. Even updating the firmware hasn't messed it up, do whatever change they made sticks. Te part that bugs me is they were pretty aware of the issue when I called and said I had an FZ6, so I wish they could make the change ahead of time. But at least it works well. Dyno run is set for the spring.
The autotune, however, is another story altogether.
Scorpio
When they reflash/unlock the ECU is it then accessible to a tuner so you can remap it on the dyno?
No the reflash is a one time deal. You tell them what mods you have and they adjust the flash around that configuration.
When I had the FZ1 flashed we compared the before and after CO% results on the dyno (Custom tune vs. reflash). They were spot on, no need to tune any further at all. Trim values were only 1 or 2 points one way or the other, or within margin of error ranges. Also the WOT sweep test plots laid on top of one another. I sold my PCIII.
Too bad there is no-one in/around Belgium that will do the ECUnleashed flash...
Closest I can find on the ECUnleashed site is Denmark
I guess it will be the PCIII for me.... :don'tknow:
Grtz,
Degake
Grtz,
Degake
Turn around is pretty quick.
