chunkygoat
Off the bat it sounds like you either have a crimped fuel line, clogged injector, or blocked air intake. Twisting the throttle would only worsen it and dump more fuel while still suffocating the engine - or vice versa and run extremely lean and flood it.
I would check all your lines. Try lifting your tank and find the fuel lines and see if you can find a spot it was pinched at. The tank itself, resting on the lines, can do this if you aren't careful.
This definitely sounds like an air fuel ratio issue. If every cylinder is running, its safe to rule out spark plugs, clutch, transmission, etc.
So I would guess either fuel lines pinched, blocked air box, or maybe you've accidentally created a lot of back (or front) pressure unintentionally.
