Project TRX! A semi faithful restoration! Finished! :)
Should i leave the bike with OEM Paint scheme?
  • White frame, and plain RED OEM paintwork
    Votes: 6 27.3%
  • White frame, RED bodywork with WHITE racing stripe full length of the bike
    Votes: 16 72.7%
  • Total voters
    22
  • Poll closed .
Australia
re: Project TRX! A semi faithful restoration! Finished! Video & photo's now up! :)
Ok, here is a list of everything that i have had to buy, repair, restore, re-build, along the way....
New Asashi Wave profile rear brake disc
New Asashi Wave profile front brake disc's (Gold Centre)
Workshop manual disc
Brembo rear brake pads
Front wheel bearing's
Rear wheel bearing's
Coerce Racing billet aluminium rearsets
Haymes Manual
K&N Oil & air filter
Rizoma grips & bar-ends
Throttle cable assembly - 4NX-26302-00
Clutch cable Assembly
Hose
clamps x6
Renthal rear sprocket (40t)
Supersprox front sprocket (17t)
DID 525VX GB-120 X-ring FB pro Street chain
Frame spools
Oxford LED indicators (x2 sets)
Oxford indicator spacers x 2 sets
Front brake lever - OEM
Rim Stripes - with TRX850 lettering
Replacement swingarm
New coolant recovery tank
Swingarm pivot oil seal, Swingarm pivot bearing's, washer
All Balls head bearing's
Blast, Weld & Powdercoat frame
General polishing (Brushing)
"New" OEM Seat & Fairing unit
"New" OEM rider & pillion seats.
"New" OEM indicators with clear lens.
Polished Headers
Powdercoated Wheels
Tyres - Dunlop Q2 - 120/60 x 17 / 160/60 x 17
Strip carburetor, clean, re-assembly
Ultrasonic cleaning of carburetor's
O ring Carbs x5
Shock fluid
Shock seal bump rubber & Spring spacer
Rear Shock Rebuild & Shock linkage re-build labour
Rear Brake Caliper re-build labour
Caliper Seal Kit
Polished (Brushed) Clutch cover
Grommets for tail light (Clark Rubber)
Paint ( Bunnings )
P47 Grommet's x4 (Fairing mount)
Screen - Solid Black / MRA
Plane bearing - crankshaft (brown) x4 - 3LD-11416-20
Plane Bearing - crankshaft (black) x2 - 3LD-11416-10
Plane Bearing - Connecting Rod x2) - 3LD-11656-10
Plane Bearing - ConnJ X2 - 3LD-11656-30
Cam Chain - 94591-40138
Piston ring set x2 - 3VD-11610-40
Piston (1.00mm overbore) x2 - 4NX-11638-00
400 Circlip PO12 X 2
Crankshaft and 1 connecting rod (Secondhand)
Gasket & Seal set
Fabrication - header pipes (41mm, 48mm, 50mm) & Modify GYTR FZ6 Cup race pipe
Ceramic coating - Headers
Exhaust Valve ( 5PS-12121-00) X 4
Intake Valve 2 ( 3LD-12112-02) X 4
Intake Valve (3LD-12111-02) X 2 @
Polished (Brushed) Rocker Cover & Remote Oil reservoir lid
Rebore & Hone
Face Head & Barrel
Machine seats
Port & Polish Cylinder Heads
NGK spark plugs x 2
Exhaust Bolt
Engine Paint x 2 cans
Exchange Shim
Belray Engine Oil / 10W-40 EXL
Coolant
Dissassemble Motor / Clean all parts
Beed blast all parts/ clean / mask / paint
Plastigauge all bearing surfaces /
Check piston to valve clearances & squish /
Install vlaves / re-install valves / Shim /
Modify Cam sprockets / dial in cams / Reassemble Motor /
Install motor
Dyno Tune
Engine Mount Spacer
Performance Cams - Ivan Tinghe ( Based on R1 Cam profile)
Dynojet Stage 3 Carbie Kit
K&N Air Filter
Clutch return spring...
It's quite a list....
And this doesnt include the many hours spent re-building the wiring loom, or the many hours cleaning stuff up, painting bits and pieces, etc...
:thumbup:
Humperdinkel
Resident Rumologist
Ipswich , Australia (+10 GMT)
Haymes Manual
Hose
clamps x6
Frame spools
Polished Headers
Powdercoated Wheels
O ring Carbs x5
Shock fluid
Caliper Seal Kit
Paint ( Bunnings )
Gasket & Seal set
Rebore & Hone
Face Head & Barrel
Machine seats
NGK spark plugs x 2
Exhaust Bolt
Exchange Shim
Coolant
Install motor
Dyno Tune
Engine Mount Spacer
K&N Air Filter
:thumbup:
Now all you have to do is put a money value on all that , include labour & proceed to have a heart attack :eek: :eek: :BLAA: :D
Australia
i have already done that...the spreadsheet is rather "impressive", but not as much as you might think, after looking at a list as long as that....
as for my time, well, when it's a labour of love, time is relative.
:thumbup:
Australia
Well, another little bump in the road....the Dynojet Kit that was sent, was the wrong kit, now waiting for the right Dynojet carbie kit to arrive...
The weather is awesome here right now, so i guess it's good, that i have another bike to ride!!!
:thumbup:
Tiger Eyes
Australia
Either you are single or your significant other is very patient. When I did my TRX in London there were a lot of Sundays that I had to put ear plugs in to drown out the complaints from the wife. I did however, convince her to ride with me once. I am very jealous of your project and I have been following it and showing it to my wife - looks at me as says no way in hell. Congrats at getting this far with it and staying true to the original design.
Dave
Australia
Dave
Lol...single! I have a Missus, an ex Missus, and my 2 kids living with me! But all are very encouraging, and in fact, both the girls are very anxious for me to finish the bike, so I can take them for a ride...as I recently sold the only bike in my shed with 2 seats, to help finance this project...
The secret is to make your workshop a comfortable place for others to hang out...I have a lounge area, a bar, the Internet, and a dress up box in my shed!!! Yes a dress up box...the girls like to do impromptu "fashion" parades from time to time...
As for the bike, I set myself a deadline for the project, which has kept me on the job...deadline has passed, but bike is oh so close to done! So that worked. :)
My attention to detail re doing the best possible rebuild within my budget constraints seems to have paid off with the motor re-build, as the engine is delivering some very impressive dyno results!
I just wanna get on the thing now, so I can see how it rides, how my braking mods have turned out, and so I can get the rebuilt suspension sorted.
It has not been a cheap re-build!!! In fact I have spent just a little more than a TRX would of cost new in Australia...so about $12000!!! Exactly twice my original budget!!! But I do have a better than new TRX for my trouble....15kg's lighter, 35-40% more power, better brakes, and upgraded suspension.
Thanks for the nice words.
:rockon:
motojoe122
No ride is too far...
Somers Point, NJ
Ahhh, Wolfie has his cake and gets to eat it too!:BLAA:
That bike........is SOOOO nice!
just james
saint louis
I think it looks great never saw one berfore. Leave the farrings on paint frame white or silver the rest candy apple red flake with the wheels painted the same to match.
Australia
The frame has already been powdercoated white, as have the wheels, and the fairing's, seat unit, and tank are now all staying original....the paint on seat & fairing unit are in exceptional condition, as are the decals, it's only the tank that needs a bit of loving...couple of small ding's, and a wee bit of rust around the feul cap...an easy fix...next winter!
So the bike is 100% original in terms of frame, wheel, engine, fairing, seat unit, and tank colurs.
:thumbup:
Australia
Still waiting for carbie kit to arrive, apparently it's in Australia, but even if it arrives tomorrow, nothing will happen till early next week, as the shop that is doing the work, are away tomorrow...
Waiting.....
Australia
Going slightly insane! I want my bike back, and i want to ride... Aint going to be till about Wednesday next week i reckon....pretty positive of that, but now it's oh so close, it is driving me nuts!
I cant even really ride the FZ6 right now, cause it's tyres are screwed, well, they are well past the wear markers on the sides at the front, and the rear is on the wear markers...and there is a Police blitz on bikes right now, so i dont wanna risk a $400 fine...
Everything is paid for, bike is being registered on Monday...am going to get a personalised plate...white plate, red lettering. I can get the numberplate in the following formats...
AAAAA 0
AAAAAA
AAA 000
Some plate number combination's i am toying with the idea of getting...That are available...
TRX868 ---- My favourite, and definitely my first choice right now. :thumbup:
TRX 868 ----My second choice right now...
WOLFMAN
YAMTRX
TRIXY
TRICK
YAM 850
868TWIN
850TWIN
Some input please....what does everyone else who is interested think...any of these, or something else????
Some inspiration would be great....
:thumbup::thumbup::thumbup:
Australia
Ohhh Jamie thats a no brainer TRX868 easily wins my vote :rockon: :rockon:
That's what I thought...so I reckon unless someone comes ip with something out of left field, that's what it's gonna be. :D
spock
Medellín, Colombia
go with the one Humperdinkel says, immediate winner for me as well :thumbup:
agf
Go Naked- Its liberating
Melbourne Australia
+1 from me too
Sent from the phone: sorry 'bout my spileng, fat fingers...you know!
Australia
+1 from me too
Yeah, that one, the TRX868 has been the choice for a while now....but i do like to bounce idea's around, thanks for your input boys.
:thumbup:
Australia
Just spoke to the shop, bike is back on the bench, carbie kit is being installed, looks like it should get back on the dyno, sometime later today...
Looks like i could have the bike back tomorrow!
:rockon::rockon::rockon::rockon::rockon::rockon::rockon::rockon::rockon::rockon:
Australia
Woop! I am now the official registered and insured owner of a 1995 TRX850, with my personalized number plates ordered...they should arrive in about 2 weeks!
OMFG! Been waiting nearly exactly 12 months for this moment! This is number 2, of 3, in the "big moments" re this build... The first was the motor running again, which obviously has been, the third, might just be tomorrow...riding the bloody thing for the first time!!!
Excited much...I can't contain myself! Am bursting!
Humperdinkel
Resident Rumologist
WOOOOOOOOOOOOOOO HOOOOOOOOOOOOOOO , way to go Jamie !!!! :cheer: :cheer: :cheer: If it were me i'd be ovulating with excitement :eyebrow: :D
What time does the shop open in the morning ?? I want a ride report as soon as you step off the monster :thumbup:
Australia
LOL! I stopped at the shop this arvo with Mikey, bike was back up on the dyno, and it sounded oh so good....even better than the last time i heard it.
Tuning was not quite done when i left the shop, a little more to do in the morning...
A Stock TRX pulls a maximum 76hp at 7450rpm, this TRX was pulling about 95hp this arvo at 9000rpm...so still a bit of jetting work, and sorcery with the ignition timing, etc, tomorrow morning, and then i will be picking the bike up at about 1.30pm...
I cant describe how good it sounded today, like a highly tuned V-twin in full race spec...
When i get it home, i need to change the engine bolts over for the Pro Bolt anodised black bolts i have sitting here, swap out the LED aftermarket rear indicators from the bike, and install the "new" OEM rear indicators with clear lens, and swap out the tail light with the "new" tail light i have sitting here, and swap out the blue LED dash globes that look crap, and replace with the OEM 7W globes....just getting little details sorted....
Oh, and i have to get busy with the razor blade and shave the excess gasket's from the engine covers....the gaskets are aftermarket, and a little big, and are green, so they need a little trim...more minor detail stuff..
But before any of that, i will be getting a base suspension setting sorted tomorrow, and going for a spin in the Twisties, to see how this baby go's!!!
WOOP! WOOP!
