redoliander
When checking at 4k do you just adjust the idle up then when done you put it back between 1100 and 1300?
I'll probably do the latter...it'd probably be a pain doing both yourselfno. I believe you have to turn the throttle and hold it there as you adjust. or ask a buddy to assist. Might cost ya a beer.
It's really simple, there are a couple of sticky posts on it. One of them tells you how to build your own manometer for less than 20 dollars. That's really all you need. The first time it took me about 45 minutes to sync them, the second time it took 20. Very much worth doing.
I've got the levels about the same at idle but when I rev to 4000 #2 shoots way up. So should I adjust for the 4000 to be the same levels or at idle?
Idle
4000
Tried syncing them again this morning. Same results Could my valves be out of spec and causing this? If I set them at 4000 then at idle #2 is really low. This can't b this hard!
But even if the valves are out of adjustment, shouldn't I still be able to get the TB's synced close?
