AJ Babaganoosh
I am about to have my rear sets powder coated and I am having some trouble I hope someone can help me with. On the inside rear of the gear shift lever there is a ball/socket joint which connects the lever to the shifting rod. This ball/socket joint has a rubber boot on it which means it is going to need to be removed before powder coating. Problem is, I cannot figure out how to remove this from the shift lever. There are no nuts/bolts/screws. I initially thought it would just slide out of the hole in the shift lever. However, I can not get it to move, even with a hammer and punch. Does anyone know how to remove this?
