She won't start
mongol777
Toronto
She won't start
Came to office today, shut off bike using kill switch so fan can cool it.
While cooling - dash went blank. I saw it happened before - turn blinkers, fan, etc is fine but dash is blank. First time it happened it was ignition fuse.
So I went to my office, dropped of my gear and went back to replace the fuse.
All fuses checked out fine and I decided to try it again - dash is now on, I hear fuel pump, no warning indicators but bike won't start - see video:
fz6 won't start - YouTube
Battery is fresh - installed about a month ago, bike is ridden daily rain or shine. First time ignition fuse was blown about 2 months ago - I actually dropped it off at Yamaha shop and they told me that it is likely because grip warmers were wired to ignition. So I removed them completely, bought new ones and wired them properly to the headlight.
I think I'll be able to bump start to get home but would like to know what is going on.
greg
UK Luchador
Stockport, UK
if the fuse has blown before then it probably indicates some underlying problem (maybe something drawing too much power, or a short circuit)
mongol777
Toronto
Fuse looked OK this time and as couple of my friends pointed out - it is likely battery. Dash likely went blank because fan is big power drawer. What else can be drawing power?
ChevyFazer
Redneck MacGyver
ATL
That clicking sounds like the same noise thy make when the battery is dead or low. But if you are %100 sure the battery is good then it has to be in the starter circuit, maybe the solenoid.
Your battery is dead.....Why it's dead is going to be what you want to find out. :D Or you have a very very poor connection at the battery.
Check your connections at the battery.
Notice how the voltage dumps when you activate the starter. As soon as there is a load the instrument cluster readout goes until there is not enough current to run the starter relay.
If you jump start the bike from a car make sure the motor on the car is turned off and not running.
dpaul007
Lake Crystal, MN
Looks like it's not getting enough juice from the battery. Are your accessories turned off? Or do they come on with the key? Also, double check the connections to the battery to see if they are loose. The guy I bought my bike from installed the battery when I bought it, about a month later the bolts/nuts rattled loose, causing some issues similar to this.
Maverick
Ottawa, Canada
I would suspect the battery... you will need to find out why it went down if it's only a month old- short, loose connection at the starter, or bad alternator.
mongol777
Toronto
OK, now I need to find out why my battery died so soon :)
I will not jump start from the car - I'll just put it in second and do fast duck walking :D
Connections should be solid - I check them every month or so but will double check again.
mongol777
Toronto
Yep, all accessories are off with the key. I don't have many - R&G grip warmers and PCIII
04fizzer
Fairport, NY
For starters, there's no advantage to leaving the bike turned on after shutting it off. All you're doing is killing your battery, so stop doing that. You may notice your battery lasts longer.
mongol777
Toronto
Well, I used to do just that but doesn't manual state to leave key in "ON" position while fan completes the cooling? My buddy's VFR had same feature and it was fine for years and years.
ste
Surfing the ethernet
Dublin, Ireland
if you are hearing a clicking sound
it may be regulator based problems that you are having
i had a yamaha majesty 125 a long time ago
and the electrical system was useless
id been around most garages in my area to be told its the battery, then told its the alternator.
but i think it sounds like the regulator
check around the image below with a testing kit and make sure it has good connections
04fizzer
Fairport, NY
All that would do is cool what's in the radiator. There's really no point to it.
mongol777
Toronto
Got it - makes sense. But why would Yamaha put such feature in the bike? If rad is too hot when u start the bike - it would just turn on the fan, right? So why it needs to be cooled down after bike is shut off?
mongol777
Toronto
Will do - thanks!
04fizzer
Fairport, NY
Nowhere in the manual (at least for the 2004) does it say it's necessary to leave the bike on to let the fan run.
The fan runs because the key is on and the coolant is hot. It's just the way it works. It's not doing anything for you other than running your battery down.
ste
Dublin, Ireland
also 1 last thing check that you are not leaving the parking lights on, if you are using the steering lock
mongol777
Toronto
You are correct - just checked my owners and service manual. Will not do it anymore!
