- Joined
- Feb 7, 2009
- Messages
- 12,556
- Reaction score
- 1,208
- Points
- 113
- Location
- Cape Coral, Florida, USA
My apologies Scott, in my previous post I thought you were referring to the larger spring housed within the switch that moves the contactor back and forth - that one is ok
However the smaller spring, which is beneath the contactor housed in the switch, was completely rotten therefore the contacts can't come together
You hit the nail on the head with that one! Will I have to replace the whole thing for the sake of a tiny spring?
I wouldn't...
I'd either hit the hardware store for a spring, or depending on how big the hole is, it sits in(I fogot, its been years since I had it apart), cut down a "pen" retractor spring. I don't know if that would be taught enough, but where it sits, should give you an idea how large (width) the spring needs to be.
Seems somebody else had an Oh $hit moment!!! Boing, where'd that damn lil spring go???
Glad you found it!!
And pack it with some di-lectric grease (if you re-use the switch) just to keep the moisture out and it happening again..
