Speedometer Question
rdoucet
Ghost Rider
Plainfield, IL.
Have a 2006 and want to convert the speedometer to the new version like the 2007. Does anybody know if this can be done easily; wiring should be the same but worried about installation in the fairing. Any help would be appreciated.
Thank you to all
You will need an 07/08 wire harness to make it work,but it will look out of place since the holes for them are totally different.
You'll definitely have to modify the fairing, or install one from an 07/08.
The mounts are different, and so is the wiring harness.
Crazybiker has done this mod, and I believe he said if you can get a 07 headlight/speedo harness it'll be plug and play with the bike's harness.
