ajporlier
Hey, I just bought a 2006 FZ6 with 12,000 miles on it. However, after about a week of riding it I semi-frequently stall as I'm stopping at a light or a traffic signal. From reading around this would seem to be a TPS issue. But the bike also sometimes has a problem starting up, the starter will crank but the engine won't turn and a check engine light will come on. But if I shut off the switch and try again, it will usually work fine without any check engine light. I used the gauge cluster to find out that the battery is putting out just under 12 V before the engine is running, which I'm wondering might be part of the problem too. Any help?
Thank you!
Thank you!
