stupid Q, will a 04-06 Fz6 stock pipe fit a 07-09 fz6?
yellowr6
bay area
hi,
i tried googling it and also used the search bar but no luck.
i have a 09 fz6 two bro pipe. its too loud. i know 07-09 are the same and 04-06 are the same.
will a 04-06 pipe fit my bike?
thx.
Are you asking about the mid pipe?
Ron Ayers lists the parts as different prefix numbers but they may be swappable. S-1 series pipe is $200 plus the S-2 pipe is $500 plus. :eek:
Mid pipe is NO! Its about 1.5" shorter.
FWIW: The S2 mid pipe CAT is about 3 times the volume of the S1. Pipe is also 1.5" longer or so.
53707d1402330661-catless-mid-img_20140529_204643_900-jpg
JJD952 - Exhaust
hi,
thx.
No - and it won't solve your problem. It will likely make it worse as the S2 has PRE-CATs in the header. Removing the CAT's - makes the tone sharper. More of crack.
Buy some XP1 inserts for the Two Bro pipes.
Differences:
S1 (top) to S2 Header
Notice that nasty sharp angle at the O2 sensor and the S2 has Pre-CAT's just before the 90° bend.
55355d1412788891-unofficial-fz6-compatibility-chart-s1-s2-header1-jpg
Also notice the mounting bracket is offset between S1 vs S2. The S1 flows better and has less restriction as it offers a smoother transition into the mid-pipe. However, you may need to add an O2 bung for S2 use.
In short: the FZ6 Muffler sections interchange between all years. The Mid-pipe if swapped during muffler change need to match the header.
S1 header + Short Mid-pipe
S2 header + Longer Mid-pipe
2007Z6ALL-LED
Southern California
you got any citation because of being too loud? I would rather leave it as loud as possible for your riding safety so cagers are always aware something loud coming..and they will probably slow down!
That's wat I wanted to do but due to the price...$600 ,,,too expensive for me at the moment!
