To all the R6 fork modders RADIAL CALIPERS ARE HERE!
Discofrank
Lesmurdie
well looking at a local forum i was sent this link
Brembo_radial_calipers_transformation_kit_for_Yamaha_R6_99_02
radial caliper kit for 99-02 r6 bikes = the forks WE put on our bikes
now if i could just get the brackets i would be happy:rockon:
Product: kit trasformazione completo pinze radiali Brembo per Yamaha R6 99-02
Question: are the brackets for the callipers available seperatley or only as a whole kit?
Answer: Kit is only sold as whole
i guess not :( :(:(:(:eek:
Hellgate
Moto Demi-God
AUSTX
Now that is trick. Who's going to be the first to pony up for these puppies?
Fred
M em b er e d
Austin, TX
www.robietech.com
At $1500 for a kit, not me. But they are cool looking.
I'm saving my money for the 67 Mercury Cougar project.
Fred
Hellgate
Moto Demi-God
AUSTX
Fred
Cool car, do tell, on a seperate thread of course.
Wavex
Lazy Mod :D
Long Beach, CA
A bit expensive to get better looking calipers... I've read multiple times that for the average Joe, radial mount makes virtually no difference to braking performance...
Hellgate
Moto Demi-God
AUSTX
Oh you fuddy-duddy, we all know it is about how you LOOK. :BLAA:
LERecords
Shelburne, VT
umm.. the mod is for 03-04 forks.. not 99-02.. might work, but someone with more engineering experience might be able to shed some light on this.. has anyone emailed the company asking to demo a set on the fz6???
Wavex
Lazy Mod :D
Long Beach, CA
Sure but $1500 to get gold instead of black calipers sounds expensive :Flip:
It says 99-02 on the website... where did you see 03-04?
How could they demo a set on an FZ6 since they're made for the R6?
MRGM
Michigan (GMT-4)
Radial brakes perform better because the force transmitted to the fork leg is straight through the mounting pads, instead of laterally through the bolts holding the caliper onto the fork leg in a conventional setup.
You're a fool if you think bolting an extra conversion mount, inbetween the caliper and fork leg is going to get you anymore brake performance. Heck, I'd say they might work worse that stock!
Wavex
Lazy Mod :D
Long Beach, CA
Yeah well it's a bit more complicated than that :)
RADIAL MOUNT CALIPERS; what's all the hubbub, Bub?
Interesting how things that oftentimes appear to be a radical departure from the “norm” are in fact evolutionary rather than a genuine fundamental revolution. The new buzz on Radial Mount Calipers is straight from the automotive industry with a few minor tweaks. With cars, they’ve almost always mounted the calipers in a fore and aft manner because it’s a straight up simple and strong way to do so. Granted, the new motorcycle version has finally taken that lead and adapted the concept by incorporating a radial mount instead of the commonplace perpendicular (90 degree to rotor face axis) mounting bosses universally prevalent today. In reality, whether calipers are mounted radially or perpendicularly is of little consequence, having only to do with the fact that the new generation calipers can be made a bit lighter via the radial mount set-up (no other significant performance difference here).
I know I’m going to disappoint more than a few technophiles here by stating the Radial Mount design in and of itself offers no real world performance gains beyond improved pad wear characteristics, and that is almost strictly focused on the near elimination of TORSIONAL caliper flex. Bear in mind and heretofore, all conventional calipers are mounted at the trailing edge of the line of force, combined with the fact the energy transfer (to the forks) of the braking forces are all focused on just one side of the clamping pressure as applied to the spinning rotor. Then factor in the normal production tolerances between the mounting faces of the rotor/wheel, fork/caliper, plus perpendicular axle alignment within the wheel to these faces, and more. Of course we can stir the pot with greater possibilities for misalignment with (even just slightly) out of true axles and fork tubes. The end result is there’s always some degree of mating issues that ultimately effect performance potential yet are still within factory tolerance. Depending on degree of misalignment, a torsional twisting effect of the caliper can come into play during hard braking. This usually manifests itself with radial tapered (bottom to top) pad wear, brake howl and piston retraction problems due to this distortion. The relatively new radial mount caliper design virtually eliminates this torsion flex problem since it more efficiently spreads the load both fore and aft to the line of force. It also offers the additional advantage of better (quicker) release at the end of the braking sequence (FYI: brake pad compounds play a large part here, too). Which from the racing perspective provides a cleaner transition when braking into the apex on the edge of disaster. This is a very good thing indeed. But again, something you the average weekend warrior will not likely feel at the lever.
As a sidebar, the single action calipers (live pistons on one side only) such as what came on the CBR600F3 (and is standard on virtually all Motocross bikes) have categorically fallen out of favor for use on Sportbikes. This is primarily due to the fact they suffer from unavoidably greater degrees of flex inherent in the calipers floating pin design and minimal piston area (compared to the modern double action calipers).
The Real World of Greater Performance:
Here’s where it really gets interesting: incorporated into the design of the new generation Radial Mount Calipers is the latest in braking technology led by two basic concepts. Of course there’s more to it than just this, but in an attempt to keep it simple, the elements can be effectively identified by these two separate yet related categories:
1. CALIPER STIFFNESS
2. BRAKE PAD DESIGN AND THE LEADING EDGE
Caliper Deflection:
The difference in deflection between the O.E. calipers and the dedicated racing caliper is remarkably quite large. Rigidity plays a major role here. And there’s also a surprising difference between the various O.E. manufacturers in this critical area of stiffness. Bear in mind that on a World Supersport spec heavy braker, we found vertical (up to down) pad taper, just a tenth of mm (.004”) but this is clearly representative of an existing problem. Under severe conditions, caliper deflection is manifest as either inconsistent braking performance and/or a somewhat vague feel at the brake lever. Other factors such as fluid integrity, i.e. relative to water saturation point and resultant resistance to fluid boil (wet vs. dry boiling point), plus backplate flatness and to a lesser extent, friction material compressibility all play a significant role here, too. This is clearly demonstrated on the research dyno where simply changing calipers on the test fixture (with same compound pad and rotor) equates to sometimes dramatically different friction level curves. This is much more pronounced with O.E. calipers than the high-end billet racing counter-parts…but in all fairness, the production O.E. calipers still do a very good job overall, particularly when cost is factored in.
Another fundamental and crucial difference here is with material and manufacturing techniques. Production machines invariably use mass produced cast calipers versus the race-bred gems found in SBK & MotoGP. Those are the real beauties, CNC machined from substantially higher tensile strength billet stock and often sporting ventilated Titanium pistons. The differences are again manifold but paramount is superior rigidity combined with a typically longer and narrower pad shape. The Narrow Track layout focuses the applied braking pressure over a somewhat smaller area, optimizing [in microseconds] the reaction time of the braking forces. Of course another advantage of the race specific calipers is their lighter weight due in large part again to the higher psi capabilities of the premium grade billet material.
With cost always an issue with production bikes; brake designers went back to the drawing boards to boost performance while keeping a bean counters check on cost considerations.
Brembo again forged the way forward with the introduction in late 2000 of their stunning Four Pad caliper, which found a home in both the Aprilia Mille and the Ducati 748 and 998 R models. These were the first of their kind using the individual pad per piston design in a mass produced production caliper. They wisely addressed the performance advantages of increased stiffness with the addition of a massive bridge over the top of the pad cavity opening, greatly increasing resistance to distortion.
PAD DESIGN, the Leading Edge:
The new generation Brembo 4 Piston Caliper design was then further enhanced by incorporating four separate pads operating with larger equal sized 34mm pistons (than their 30/34mm twin pin forerunner). The necessity of using differential bore piston diameters to reduce pad taper (fore and aft) became a moot point when switching to the short individual pad and piston arrangement. Greater piston area mated to a properly sized mastercylinder piston (ratio) improved performance values. But there’s an additional benefit to the individual pad/piston configuration: greater initial bite. Inevitably, as the pads friction material bears down on the rotor during braking, each leading edge acts with greater force than its trailing counterpart, adding additional grip in the process. Think of it in terms of the friction material trying to wedge into the rotor. More leading edges…more bite. Although this is for the most part noticeable mainly in the initial braking sequence, but the end result is another notch up the bar in performance levels. This fact is not new having been around in the Aftermarket for years. Companies like ISR, Harrison, PM and others have and continue to offer these in various combinations. Bear in mind however, you the consumer are going to pay for this improved performance with a notably higher pad replacement cost.
And now Tokico has taken this concept another step by incorporating a beautifully sculpted individual pad/piston design into the trick looking radial mount system, debuting on the new 2003 Kawasaki ultra ZX6R/RR and Suzuki with their revised GSX-R1000 assault weapon.
So bottom line, what does it mean to you the Sportbike enthusiast and weekend warrior? In simple terms, it’s stronger brakes. Evidently the O.E.’s think enough so to warrant down sizing the rotors to improve handling and turn-in performance via reduced rotating mass (less gyroscopic forces). It will surely be of interest to all to see how well these smaller, lighter rotors will like this arrangement. Rotors with less material mass and heat sink capability often suffer more from fatal thermal stress distortion.
Does all this new-fangled brake design mean the current crop of high performance calipers are making a quick exodus to the dust-bins? Not likely. Need proof? The 2002 World Superbike Champion Colin Edwards and the mighty Honda VTR1000Sp2 used the traditional Nissin 6 pot billet race caliper all season…Old World perpendicular mount and all. Could it be Honda was too cheap to fork over the cash for the latest radial mount version? Yeah, right! Sure looked to me like the new Champs brakes were working just fine…
Hellgate
Moto Demi-God
AUSTX
Speaking of radial brakes and the sort, who was doing the USD R6 fork install? How did that turn out? I'm too lazy to search right now.
LERecords
Shelburne, VT
thats the thing.. OUR bikes use the 03-04, not the 99-02.. so this mod idea wouldnt work since our bikes dont use the 99-02 forks...:thumbup:
MRGM
Michigan (GMT-4)
True, but the most important part is that it is to reduce flex. By inserting the conversion bracket in there, you're actually adding flex to the system. It's all for looks. If you want better brakes, change your lines and pads.
Ridgeback
Wakin up the neighbours
Godalming UK
Gotta say I won't be rushing out and buying radial calipers any time soon.
All the reviews I've read about bikes fitted with them,Ducatti,new BMW etc say to be very wary with the front brake,because as awesome as they are, they can lock under the slightest touch + price wise :eek:
Top of my shopping list is the R6 fork/caliper conversion. And if the brakes aren't up to the job with them,then I must be riding like a complete wanker! ;)
LERecords
Shelburne, VT
yuppo
thast is unless i have 03-04 forks....???
the dude i got them off in the us said they where 02
disco. there are hundreds of post asking what year forks do we use.. they are either r6 03-04 or r6s 07 (i believe its 07) - 09. You were probably given some wrong info from the "dude" that you got them from.. I do not believe 99-02 r6 forks work... thus this mod would not work on our bikes.. :thumbup:
