Yes I was hesitant when I first thought of the idea of replacing the standard coils with COPs. Once I started finding some links and examples of other bikes being converted I thought I'd give it a go. Having the coils wired in series isn't ideal as if one coil open circuits the other one will too, so you lose 2 cylinders instead of just one, but that's how the bike was all along with 2 coils for 4 cylinders so there's no real change. Having them wired in series creates a bit more resistance than standard (I measured 2.4ohms with my coils in series compared to a standard original coil spec of 1.5-2ohms) so there is less current flowing through the transistors in the ECU, but a bit more resistance/less current flow is better than too much current IMO.
I played around with a neat android app called Circuit Jam and it's basically a geeky game based on electronic circuits. After you solve a heap of puzzles it unlocks components in a sandbox so I was able to create the circuit with coils wired in series and parallel. Here is the series wiring showing 2 COP coils with an average of 1.4ohms. Across each coil there's a 7.2volt drop, and 5.14 amps flowing though each coil, making around 37watts of power flowing through each coil.
Next up I played around with the idea of a parallel circuit, but to restrict the current flow though the transistors I would need a 1.3ohm resistor. This meant that now I only had 3.6 amps flowing through each coil, with 5 volts across the coils, which works out to around 18 watts at each coil.
I'm not sure how it's all going to last in the long run but so far the bike runs really nicely, in fact its been years since it ran this smoothly! The coils fit nicely but when they click down onto the spark plugs it feels like they have only grabbed onto the top thread, instead of the original caps where you could feel it clicking down on several threads on the top of the plug. I might have to look at trimming the rubber grommet to allow the coils to fit a little lower onto the spark plug but I'll worry about that if I see lots of arcing on the top of the plugs.
Anyway thank you again for everyone's help on this forum. Sorry for geeking out a bit in this post.
