zigzagg321
blue is fastest...
Wondering if anyone knew what is behind this cover? Is oil going to come out if I remove it? Thanks in advance.
You'll also need some liguid Yamaha bond sealer for around the rubber grommit when re-assembling.
I'll do the same change soon. I have the part and the gasket also.
I wonder about the sealer.
Can i use any liquid gasket sealer or a special one is needed?
I don't think i can find Yamaha brand sealent around here.
Do you also recommend using locktite while putting it back?
I tend to use Loctite where it was originally.. The cover bolts don't have threadlocker, but you might find some as colored threads where the rotor pickup bolts to the cover. The blue-strength stuff there should be sufficient.
