Carlos840
Ok - this has been repeated twice now and I strongly disagree with this advice!
Exceeding the range of torque designated by the manufacture can can damage the wrench and make it produce unreliable results. DO NOT EXCEED THE TOOLS RANGE! i.e. "give it a slight extra nudge" it can render the tool inaccurate thus defeating its purpose!
If its range stops at 80 ft / lbs (example) and the user keeps bearing down on it, past 80 ft/lbs it can damage the tool. Its not a cheater bar and should not be used in this manor if you want it to remain accurate.
I give the extra nudge with my breaker bar... I would indeed not recommend doing it with the torque wrench, i thought that was common sens!
