mckebabs
Hey guy, I’m new on this forum. I recently bought my first motorcycle fz6(2005) and after I accidentally left the lights on overnight the problems started. Now after I have changed the battery it doesn’t event starts – engine light turns on when I press the starter button.
So here is the history.
The battery died.To get it to the tender I push-started it and drove 40km to my home (Should I be worried about regulator-rectifier now?). Charged the battery with tender. With the bike running with high rpm it was charging with 14,3++V which seems fine and I expected that the troubles will end here.
It was going fine but yesterday battery died again. Since fully charged it had only 12.5V I decided to change the battery. Today, before installing the new battery I tried to crank it again however now when I pressed the start button, Engine light turned on and one click in the display(odometer) could be heard. I hoped that after changing the new batter the problem will disappear but it didn’t.
So far what I have checked:
-Diagnostic system. Everything seems fine. In memory there were codes 12, 30 and 46, however after clearing it, no new errors were displayed.
-Sidestand switch and Neutral switch seems to be working fine
-Main fuses are fine
-I can even push-start it without problems (should it be possible to push start in case there were fail-safe errors?)
Maybe you have any other ideas what could be wrong? My next attempt will be checking the starter relay. After that I’m out of ideas.
Thanks in advance
Thanks in advance
