I got my 07 fz6 may 27th, it came with a power commander, 2 brothers exhaust, and frame sliders. Since then, I've added red rim highlights(purely aesthetic) , stubby levers (shift and break), flush turn signals(front and rear), integrated turn signal rear led tail light, and starlight 9007 headlights (high and low) until I get the hid projectors!
But officially today I gave it a wash, fuel injection cleaner and changed out all the fuses! Next week I should have a new K&N filter.
Today, I lengthened the clutch arm and cable bracket by 5/8". Reduced lever pull about 50%. Trying to make it more enticing for my wife to want to ride again.
Today I disassembled the front forks and preparation to swap seals and oil to 10wt. No better time in the northern hemisphere to do this kind of tear down work than January-February!
This was month ago....
More powder coating goodies. For those with an air compressor to do a little bead blasting, its pretty inexpensive compared to paying someone. My boots have two full seasons against the rear sets and haven't worn through. Pretty tough stuff.
Took off the swing arm to regrease the bearings and give a general tidy up .With the chain off and a good look at the sprockets have reviled they arn't in such a good condition I first thought.
I think its the original chain and sprockets still on the bike with nearly 31,000 miles on them , probably could eek out a few more miles but since the bike is apart might as well fit new chain and sprockes now.
Yesterday I repaired broken turn signal mounts. Thought I'd post some pics and a brief description for others with this problem.
The PO's wife dropped the bike on both sides in the drive way, resulting in the lower turn signal mount being broken on both sides. I decided to construct a mount out of steel reinforced epoxy putty, this stuff from JB weld.
It's probably overkill for this application; Any other sufficiently sturdy putty will work.
Here's a picture of the broken mount. The PO apparently made an attempt at re attaching the broken mount using two different kinds of putty. The job was pretty slap dash (probably he did not remove the fairing first) so step 1 was removing that crap with a drill.
With everything cleaned off:
Step 2 was to building up a "mount" using the putty. Not much technique here. I screwed the turn signal into the top mount then put the thin piece of plastic the putty came wrapped in underneath the signal. I then built up the putty until it touched the underside of the turn signal, and let it set. The stuff gets kind of warm to the touch when it sets.
Ain't it beautiful? Girl friend says it looks like a giant booger. Step 3 I painted it black just to be safe. Step 4, drill a new hole and screw in a self-tapping screw. Job done.
The only thing to be careful of here is not making the putty too thin where the screw hole is going to go. Obvious I know, but I made that mistake on the other side and when putting the screw in the putty cracked and fell apart. The wall was just too thin, so I will have to re-do that side. That stupidity aside, the plan seems to be working (so far) and feels like a better repair than using a zip tie.
Fabricated new exhaust and installed. Put in new battery that was a little bigger and better than what normally goes in, designed naked front end and started making custom brackets. Put in New read LED tail light with Flasher relay(when braking it flashes for a second or 2) and integrated turn signal. Started making a fender eliminator( made a prototype). This was done this week up to today.
Did some cleaning:
Found out there is one LED strip that had a disconnection, right above the chain, but there is lot of tape holding it, it won't fall on the chain while riding though. Anyway, need to replace the LED strip tomorrow evening..!
Mother's mag, I learned, if the headers are hot, it is easy to clean with MM. Definitely less elbow grease, but should be careful not to burn your skin..!
Not today, but a couple of weekends ago :
- upgraded the stock forks on my 05 with R6 ones after
- installing new seals on the new twin pot calipers
- installing new dust caps on the forks
- Flushing the oil fork oil and replacing it with Maxima 5 WT oil
- lowered the R6 forks by 6mm to match the earlier setting I had on the not-so-stock forks, no other adjustment done.
- changed the oil/filter to blood red Motul 7100/Purolator (the rumors seems true, slicker gear changes and cooler running engine)
- adjusted chain slack
- cleaned and lubricated the chain
- adjusted tire pressure
-Fz1 handlebar replaced the Fz6R to complement the R6 swap. Sporty it is!!
It is a little over 20K miles on the bike now, might need a valve clearance check, and air filter replacement. Will get to it in sometime.
