What's the highest you raised the C0 values too?
Gap is <0.028" or 0.7mm IIRC
It should not.
Im not saying this will solve your issue but leaner mixtures are harder to burn. With an increased gap it could be a factor. Unlikely it is the sole contributor but loosely speeaking you could be 0.004 to 0.006 over spec. Keep in mind they wear over time so that gap increases as you ride. So, you might want to get that gap under 0.7 and closer to 0.6mm
OK.... spec is .7 to .6mm
When you chase yer tail cuz a bunch of little things stack up against you, don't say you weren't warned!!!
This is the video after changing the coilpack, nothing else was changed at this point.
https://www.youtube.com/embed/I-8sHXuef7I
In this video all I did was plug up one of the mufflers.
https://www.youtube.com/embed/Wpzo5dGaf0U
Hey, im trying to mock up an ecu, crank sensor pick up, ignition coils, TPS, injectors, and vacuum sensor.
The TB you have laying there likely have TPS, vacuum, and injectors. Do you want to sell them?
Post a picture. I have an ecu and wire harness.
Fleebay has the whole TB assembly with all items mentioned above for $50 shipped. Which is cheaper than a used TPS. lol
Its just a play project to see if I can build my own ignition map. What year is the ecu from?
