2009 FZ6 Maintenance Manual?
Bobasuaurs Rex
WA
Hey everyone!
New member here, I think I searched as much as I could, but I could not find anything.
I have a 2009 FZ6, and I'm failing to find a maintenance manual for my specific year. So far I've found:
Yamaha FZ6 Fazer 600 Repair Manual 2004-2008 | Haynes 4751
It's for the 2008, but according to Wikipedia, the bike is technically unchanged from the 2008 model. Do you guys know of a 2009 specific manual? Or should I just go with the 2008? Thanks a bunch!
Hi and welcome to the forum. There are two groups the S1 from 04 to 06 and the S2 from 07 to 09. Few of the service techniques or specifications changed between the two groups. That manual should work fine for you.
That is not to say there are not changes or differeneces. There are plenty. Some are cosmetic, some are functional. The most notable differences are improved braking on the S2 front caliper, the instrument cluster, O2 sensor and exhaust change (emissions related), and perhaps a minor safety item being the output shaft locking nut on the S2 is less prone to loosening....
They are very reliable bikes when properly maintained.
Two noteable issues apply to both; do NOT jump start them from a running car and IF it takes more than one finger to operate the clutch, lube the cable several times and ride it. If it doesn't loosen to point of pulling with one finger, replace the cable.
Use the search function. Many questions have answers!
Be safe!
The 2004-2006 is the "first version of this style"
The 2007-2009 are all pretty much the same as the above but with some upgrades/changes.
Yamaha makes two DIFFERENT manuals for each of the above...
PM sent........
Senior
My brother is Junior
Berkshire, UK
Welcome to the forum
The Haynes manual is good for both the S and S2 models.
(but be certain which one you actually have, mine is the first version , built in 2005, 5VX6, but registered in 2007 )
Sent from my HTC One M9 using Tapatalk
I'd also would appreciate a copy of the service manual. Just picked up a 2013 FZ6R last week! :-D email: [email protected]
Welcome to our great forum! Try this forum. https://600cc.org/
This is the FZ6 forum. The FZ6 is a different bike from the FZ6R and you're more likely to find a manual at the FZ6R forum at the link.
How do you know if you have a FZ6 or FZ6R?
A simple way to tell is look at your ownership papers. Another simple way is to observe what your frame looks like. If it's tubular steel it's the FZ6r. If it's the cast aluminum frame it's the FZ6. There are quite a few differences.
lrojasma
Colombia
Here you go.
It applies to all the models, including the ABS 2009 models (FZ6-AHG, NAHG and SAHG) all models cover here.
  • Yamaha_FZ6_20072009 - FZ600 Gen2_ALL_VERSIONS_Service_Manual.pdf
