chris2676
Hi, hopefully someone on here can help!
I have a 2004 fz6 with 22k on the clock, the problem I am having is the bike will start fine, when you pull off and open her up the bike "bogs down" win no response from the fully open throttle.
The issue started with me removing the cam chain tensioner as it was making a noise. It was refitted and all was ok. When riding home that night I noticed it was struggling for power and seemed to be suffering from fuel starving, I removed the fuel pump and all appeared ok.
I have then checked the air filter and spark plugs, coils, ht leads and all are ok.
Still the bike has the issue,
If you ease the throttle on gradually the bike will pick up speed and the revs increase in any gear, however give it full throttle and it makes a loud growling noise think this sound is air related and the bike just bogs down.
It has also to add had the tps sensor changed under warranty, and there are no active fault codes
Please please help!
Please please help!
