FZ6771
I really opened up the box this time, and it runs great!!!!!
Excuse the First post....I really opened up the box this time, and it runs great!!!!!
I iz afraid to do the airbox mod, Im sure Surdyke Yamaha has a reason for its design.
Yes that's correct, when you get on the gas now there is a giant sucking sound! It probably wouldn't work well with a 100% stock FZ .Pic #1 is the 'after' shot, right? #2 shows the wrap on the pipe that replaced the cat?
Good work.
There is an article that was posted (By Wavex I believe) from Cycle World that describes how airboxes are tuned to help out midrange power, resonating frequencies and so on. It basically said airboxes are designed for both sound and power enhacement. The thinkness of the plastic is probably a factor in making sure the are not unwanted vibrations as the air goes to the throttle bodies.
I love that loud sucking sound!Yes that's correct, when you get on the gas now there is a giant sucking sound! It probably wouldn't work well with a 100% stock FZ .
I remember trying this mod on my RZ350 back in the day (with Spec II pipes). I remember thinking that the new loud intake honk was awesome... I then went to bigger carbs with individual K&Ns. Has anyone here seen a dyno plot with the drilled airbox on the FZ? I'm curious if the intake honk and "wanting more power" are supported by dyno time (not just the butt dyno).
I got 3.5 more HP on the dyno after i modded my airbox (and the pipe, airfilter, fuel set up was identical, and both dyno reads were done by the same operator, on the same dyno)...
Have even thought of taking it away completely, and attaching pod filters to my velocity stacks!!! then getting the bike re-mapped again on the dyno..
:thumbup:
:thumbup:
I would think you could do the 'ultimate' run, just by taking the lid off the box, and running one run on the dyno without it...... that would be the least intake resistance you could expect......
