Blackops272
Keeping it short and sweet, you guys/girls got any tips for winter storage? i havent got a battery charger yet so i couldnt keep it on a drip charge
What I did:
Filled tank with stabilized fuel
Wash and wax
Lubed chain
Oil change was done under 500 miles ago, so I'm letting that slide
Removed battery (don't have a charger yet, either)
Put on center stand and covered
stabilized fuel?
i've washed it all down and covered it up and it's in my garage
need to do a oil change on it so i might do that soon
my battery is under my tank and i haven't a clue on how to get the tank off and get in to it
Fuel stabilizer - available at Autozone, Pep boys, etc.
Yes - do the oil change before winterization... keeps the insides nice.
Tank lifting is easy. There are plenty threads here that describe this.
It's a lot easier to do with a second set of hands or some type of set up that holds the fuel tank up while you get the battery out.I'll have to see if i can take this battery out it seems the simplest option if you dont have a charger!
Best advice I can give anybody................... Move to Australia & ride all year round :BLAA: :BLAA: :rockon: :rockon: :rockon:
Good advice from all - battery on a tender somehow (in or out of the bike), perhaps some cardboard under the tires so they don't sit on cold concrete, Sta-bil for ethanol in the tank (note a lot of places don't need to label ethanol below a certain percentage - hard to get straight gas anymore). Plug your exhaust, too - I put some steel wool in a zip-loc bag (to prevent the fibers from falling into my exhaust) and plug with that. Didn't once in the past, ended up with cat food filling the exhaust from mice!
I used to go all out for storage, even fogging the cylinders with oil. I've stopped that - for the minimum amount of extra wear I'm causing (if any), I'm saving a ton of headache!
You beat me too saying it hump!!! Lol
To the op though, I don't think I saw or read where you live at, as long as its not too far north with the right gear you really could keep riding.
I swear by the marine grade Stabil, put it in pretty much any gas I'm planning on leaving for >2 weeks these days. I dunno if you can get it easily in Brit-land or if you guys have the same awful fuel we've been cursed with nowdays.
I've never bothered pulling my battery, but I use an AGM, so it's more tolerant of that kinda abuse. A regular battery probably wouldn't be too happy about it. But I remember it being a serious PITA to lift the tank when it's full, and one way or another, you pretty much have to lift it full at least once.
If you store it where mice are a problem a few traps around the bike or some mouse poison is a good idea so you won't find a mouse nest in your air box
Be sure to use a fuel stabilizer in a FULL tank of gas that's for an ethonal blend if that's what they sell in your area.
