YoungAndDumb
If I am attempting a bump start I use second as it is less likely to lock up and this also works with manual transmissions in cages too.
How fast do you have to get the bike rolling?
Is there a way I can check the charging system?
Not much more than a fast walking speed so maybe 2-3mph....
Most bikes need a functional battery to run right. I am maybe a little wierd but I would just remove the battery and take to a parts store. Have them load test it. If it fails just buy a battery. I mean the bike is sitting, Its a 6500$ lump with out all the parts it needs to work. WHEN Yamaha sends you your survey, Call them. Tell them what happened and how you had to fix it, and that it was discussed in a forum about yamaha FZ6. Its just not that much for a battery, and its one of those cost vs enjoyment issues. Just my opinion though.
I will have to try it.
But for now, I called Yamaha to find out what they would reimburse under warranty and it turns out that their records show my VIN as having NO WARRANTY... It was supposedly sold "as is".
First, if the bike was sold to you "AS IS" it must be stated in the language of the contract and when this is done it is generally in very plain view and generally signed or initialed by the purchaser (this would also be almost impossible to do with a new unregistered vehicle). When you went into F&I (finance and insurance) the guy across the desk that offered the extended warranty and such would have to have explained this to you at that time. If not, somebody better be doing some major back peddling here because that leaves the dealer as well as Yamaha open for law suit.
If this were my bike or cage I would be all over this like stink on do-do.....
Yeah, I got the impression that the Yamaha rep was going to start kicking ass and taking names (from the dealer) to get this taken care of. She picked up on the fact right away that I was not aware of this being an "as is" purchase.
Mate, I suppose that the plus side to this is that you have identified the warrety issue. It's got to easier to rectify now at this early stage than later on. I also had a similar problem with y bike.THe warrenty runs out this June. The last dealer I tok it to "Probike" were excellent. They picked up on the fact that the warrenty had not been transfered over. They still did the work in good faith. IMO that is how a bussiness should be run.I will have to try it.
I said WTF??? The 1 year warranty was explained to me and I signed 1 year warranty papers (turning down the extended one). I have no f**king clue why a brand new bike with zero miles would ever fall under the "as is" category (I'm sure someone here does), but I digress. The Yamaha rep is going to work with the dealer next week to find out what happened and do what it takes to get this thing on warranty like I thought it was when I bought it.
....meanwhile, my bike sits. :Flip:
Fair point Steve,Most bikes need a functional battery to run right. I am maybe a little wierd but I would just remove the battery and take to a parts store. Have them load test it. If it fails just buy a battery. I mean the bike is sitting, Its a 6500$ lump with out all the parts it needs to work. WHEN Yamaha sends you your survey, Call them. Tell them what happened and how you had to fix it, and that it was discussed in a forum about yamaha FZ6. Its just not that much for a battery, and its one of those cost vs enjoyment issues. Just my opinion though.
One possible scenario is that the warranty has to be 'activated' by the selling dealer - it is supposed to last one full year from date of sale. Perhaps the selling dealer is just a little behind in their paperwork processing - or - Yamaha is taking their time getting it into the system
Just a thought...
Hi, I'm a noob. I bought a new 2007 FZ6 two weekends ago. I rode it home that Saturday night from the dealer and everything was OK. The next day I took it out to do some very mild riding... learning the friction zone, smooth shifting, U-turns, etc... All low speed and low RPM stuff. I stalled it a few times that day and probably the 4th time, the engine would not turn over. I popped started it and took it home and then it still wouldn't start.
So I took the battery out and had a local dealer charget it up with a 2 amp trickle charge over night. I put it back in the next day and it started up fine. Since then I have ridden it 3 times (started right up each time, and I have not stalled it since) all medium riding stuff (a lot of ~4k RPM kinda riding), and I'll be damned!!! That battery is dead again.
This has been all day-time riding (maybe 3 hours total worth since the dealer charged the battery) and I have been riding with my high beams on.
Any ideas what's going on? Is the battery "bad"? Is there a problem with the bike? Will the high beams drain the battery like that??
Any ideas would be appreciated!
Seeing as you both have been pulling your batteries out of the bike, charging, and then re-installing, are the terminal bolts on the battery posts as tight as you can get them when you re-attach the cables? The reason why is if the contact between the cables and the post are not 100% in good contact the starter does not crank. For a poor connection, low current output to run instruments and headlights would be fine but during engine start there is a high demand for current. If the contact between cables and post is not tight, the battery cannot delivery and charging the battery would also be affected through the bike's charging system. The battery terminal bolts pass through the posts of the battery to a floating nut underneath which can slip out and not be there at all or if the cable lugs are not seated flatly over the battery terminals there is not enough length of bolt to touch the nut and suck it up. Just thought I'd mention this as maybe some are not aware of the floating nut thing.
Just a thought...
Excellent thought and in order for the process to start the vehicle would have had to be reported as sold to Yamaha
I should have mentioned that the dealer also said that the selling dealership has to activate the warrenty.
Good call
Nelly
Hang on a minute, I thought that the bikes came with a 1 year warrenty as standard?In my case, the Yamaha rep was able to look up my VIN in her records and see the date it was purchased, and it was registed as an "as is" sale, with no 1 year warranty.
