ZünRob
There is info in a lot of posts on this forum about the abrupt throttle, and several fixes for it. I however couldn't find a thread which couples all the information together and tells me what the best/most easy fix is for the abrupt throttle.
Possible solutions I found:
- replacing your catalytic converter with a straight pipe, advancing ignition and adding some fuel through O2 settings (http://www.600riders.com/forum/fz6-...le-chop-snatch-rewet-response-time-cheap.html)
- throttle body sync
However, nowhere can I find the exact cause of the problem. By determining this, we could find the best fix I'd say.
In my case: I have a FZ6 S2 2008 which I bought new. Since it came out of the box it has this abrupt throttle: after closing the throttle and opening it again there is this sudden surge, which is very annoying. If I'm not mistaken this seems to be a common "problem" for the FZ6 S2.
So, what is causing this abrupt throttle, and what would be the best fix?
My bike is still stock, and I'm thinking about buying a PC5 as one and only fix for this problem. Can anybody confirm that a PC5 as only mod would fix this problem on a stock bike?
