pookamatic
Almost made it all the way to work (30 mile, 60 minute commute, cool morning - 50F), sitting at a light after sitting in traffic, the CEL came on. It went away as soon as I pulled away. In parking lot, I let it idle, and the light returned. Again, as soon as I raised the RPMs, the light went away. The temps were high, 195-212.
There are two suspect issues at play.
1) Battery - it is only three weeks old. I did have the grip heaters on during a portion of the ride, but switched them off just before I hit the traffic portion of the commute. Measured at the tender plug, the battery reads 12.04 volts.
2) Coolant - I just changed the coolant this weekend. Partly because it needed to be done, but I had also hoped to see cooler temperatures. In the year I've owned the bike, it seems to have run hotter and hotter. On a 50F morning, I would not expect to be bouncing against boiling. The fan came on maybe 4-5 times during the stop and go portions. The coolant flush appears to have little or no effect, leading me to believe I have a stuck thermostat. Some coolant is definitely getting to the radiator - it gets hot and the fan running does lower temps.
I'm thinking (hoping) a partially stuck open t-stat is causing all these problems. The water pump and fan would be working harder, causing additional drain on the charging system. It would also hurt the temps.
Here is the result of scrolling through diag mode:
D01 16
D03 100
D05 68
D06 154
D07 0
D08 0.6
D09 0.0 Batt voltage?
D20 on
D21 on
D30 00
D31 00
D36 00
D37 00
D48 00
D50 00
D51 00
D52 00
D60 00
D61 46
D62 3
D63 00
D70 0
D01 16
D03 100
D05 68
D06 154
D07 0
D08 0.6
D20 on
D21 on
D30 00
D31 00
D36 00
D37 00
D48 00
D50 00
D51 00
D52 00
D60 00
D61 46
D62 3
D63 00
D70 0
