Baci
So before I take my bike to a mechanic I thought id get everyones input here.
My bike keeps randomly dieing when I come up to a stop light.
Some times I am in 2nd, or 3rd, etc which gear i am in does not seem to matter. Sometimes it doesnt even die.
I clutch in to down shift or stop quickly and the RPMs drop and the tack just continues to drop to zero because the engine died.
I thought maybe I should shift down through the gears as I come to a stop and not just clutch in stop and then move to first to start again when the light changes. Figured this would be best practice regaurdless....However sometimes I dont even have a chance to down shift before it kills IE last time this happened I was in 2nd, clutched in and it died before I was going slow enough for first.
Some times it takes a few tries in neutral to start the bike again.
I thought at first maybe I had some bad gas, since it was 4 years old and had less than 800 miles when I got it.....I have been through 3 tanks of premium(with ethenol, cant get it without here) with the problem still persisting.
Oil is fresh, everything on the bike is in pristine shape....the only thing not stock is it had a fender eliminator kit I think at one point but then was taken off...I assume this because the bolts have wear, and the turn signal and break wires were cut and spliced.
Is there anything you guys can suggest I check or try? I am getting sick of stalling in a intersection......embarassing and Dangerous!!
