- Joined
- Feb 7, 2009
- Messages
- 12,531
- Reaction score
- 1,176
- Points
- 113
- Location
- Cape Coral, Florida, USA
Yes, the engine runs no problem, I don't feel like there is enough drag to move the bike, I'm hoping it's the mid section adjustment. And I will check the front sprocket nut - and WILL be pissed if they screwed it up because the main reason I went to the licenced dealership to replace the sprockets is I read here that nut can be tricky.
Just re-read your first post, the clutch is slipping while riding. period..
Disregard the ft sprocket check..
Sounds as if the cable is too tight (perhaps hanging up somewhere during the install) not allowing the plates to completely press back together..
Why you have you proper free play on the lever end is odd with the issue. Should be one or the other..
