- Joined
- Mar 4, 2007
- Messages
- 1,936
- Reaction score
- 52
- Points
- 0
- Location
- Victoria, BC
This might help a bit:
Here is a discussion on aonther forum about the same thing that has some great info: LED signal Lights....what size Resistors? - bcsportbikes.com
As mentioned by Mississippi, you can purchase specific flasher relays that are ment for LED applications. Usually it has to be a flasher relay made for LEDs and not just an ordinalry 12VDC automotive flasher relay. I think this is where some confusion may lie. My bad.
Here is another specific LED flasher realy: Custom LED Electronic LED Flasher Blinker Relay - Plug And Play
From the bcsportbikes post:
My resistors for my Watsen LED front signals get friggin hot! I have them suspended off the inner faring so they don't touch the plastic. These LED flasher relays seem to be the easiest way to go than putting in resistors, especially if you are not comfortable with electronics/wiring.
You can see the two large white resistors in this pic:
About LEDs and Resistors if you are interested: Super Bright LEDs - LED Info
Hope this helps.
The load resistors you need to add to simulate the bulbs will get bloody hot. If you let the lights blink long enough they will get hot enough to melt plastic. They need to be mounted to the frame which can then act as a heatsink. It also means you can't just tape them into place.
Swapping to the LED flasher that doesn't care what the load is will fix the issue without the need for the loading resistors.
Hope this helps.
