FOURminusTWO
Hello everyone!
Fairly new FZ6 owner here who just purchased the bike back in August. I have been having a rather problem free run up until a few weeks ago when the bike refused to start after sitting in the rain for a day or two. The bike displays "Er-1" when trying to start it up. The bike will start turning over but not actually fire up. I have looked up the code and see it is an electrical issue. Although I have been able to start the bike, it's not consistent and the error still pops up in diagnostics mode even if it ends up starting.
I started digging around a bit. The previous owner had installed what I think is the naked FZ6/1 headlight and the post 2006 or 2007 meter to the bike so I decided to start there since I know there was probably some bad electrical connections made during that swap. Well after a few days of tearing away electrical tape and redoing some connections, I realized neither of these components need to be plugged in in order for the motorcycle to start up. Therefore, I know none of the work the PO did was the issue.
It almost seems like temperature may be having an effect on whether it starts or not since I've had a lot more success starting up the bike when it has been a warm day. When it's cold/wet, it will never fire up from what I can tell.
Some other things I've looked into at this point:
Here's something interesting with the spark plug: I pulled out the spark plug from cylinder #1 and held it against the frame to test if it was indeed sparking. Right before pulling the spark plug, the bike wouldn't start. However, during my test with the spark plug, the engine fired right up to my surprise. Alright... I place the spark plug back in and the bike continues to fire up from there each time I try to start it. Well I tried this again the next day when the bike wasn't starting again to make sure it wasn't by luck it starting sparking again. It ended up sparking and the engine fired up the 3 cylinders with spark plugs still in them. I place spark plug #1 back in and try to fire her up. No go this time. The bike didn't end up starting afterwards.
I'm pretty lost as to what the issue could be at this moment and I'm hoping to get some help from you all. I'm hoping to get some opinions from you all before I start purchasing new spark plugs, battery, etc. When I get time, my next step will be spray different parts with water until it stops working.
Thanks!
- Battery: 12.3 V
- Spark plug: Looked good
Thanks!
