monty400
Has anyone experienced this and what did you do?
Thanks
Thanks
I think that's when the ECU isn't receiving a signal.
I'd disconnect the battery (perhaps charge it?) and go from there.
edit:
found info
Fault code: Er-1
Diagnostic Code: --
Symptom: No signals are received from the ECU.
Open or short circuit in wiring sub lead.
Malfunction in meter.
Malfunction in ECU.
try push starting the bike. Make sure you are in neutral, ignition and start button in the on position and start rolling the bike fast as you can with somebody pushing you are at least rolling downhill and then pop the clutch in first gear.
