Everything about fork mods
1.8tbora
Stealth FZ6
I was thinking just remove the top caps on the stock fz forks as if you were replacing the springs and oil but then put the r6s springs and oil in the fz tubes and put the r6 adjustable top caps on instead of the non adjustable fz ones.:confused:
discovery
I think this wouldn't work withouth modification of internal components.
Someone correct me if I am wrong.
hot4teach
Definately wouldn't work. The inner workings on the R6s fork bolts to the bottom of the fork. There is a compression adjuster on the R6s fork that the FZ6 fork doesn't have. There are probably about 3 or 4 more reasons that it wouldn't work.
Davo
Does any1 know if 2002 R6 forks can be used on a 2005 Fz6.
I have a set of them already
Thanks
Savid
Super Moderator
Thanks
Savid
You still here? 1 post and no replies. Yes, but you need a kit and axle, fender adapter...
LERecords
Thanks to the oP for including the link to the files. I plan on keeping them up a long time for anyone that needs them!!
