Joely
Hi all, first post but I’ve been lurking in the background
I seem to have an exhaust problem, to be fair I haven’t had a chance to look properly yet but I thought I’d give you good people a chance to see if you can work out what’s going on….
My FZ6 is a 2008 S2 in black, I’ve been run SP Engineering’s GP Stubby Carbon Fibre exhausts with no baffles (DB killers) – lovely and loud!
Just yesterday after a good blast around the country side I noticed the left hand exhaust was cold and the right hand side really hot, so much so that the silver tip had discoloured with the heat. Any ideas why?
I know the right hand side can has the path of least resistance for the gas flow, but that doesn’t explain it, they both got hot before. And if anything was blocking one pipe the other would be favoured, but I covered the end of the right pipe and the exhaust gas came out of the left pipe easily enough… they both sounded the same too and rpm’s didn’t drop or rise.
With no baffles you can look into the end cans quite easily, doesn’t look like any packing material has escaped…
Over to you guys!
Over to you guys!
